Sponsored by: Auxito
missing. Wet??
Old Jul 9, 2009 | 08:28 AM
Killzone001's Avatar
Killzone001
missing. Wet??
okay so washed the truck sprayed off engine and stuff well it started missing i know i had a weak coil pack that when it got wet it would miss but never this bad. Well its been three days still ides rough. Missing badly at low rpms. The coil pack that was weak would kinda look damp but when it looked dry it would run fine well now all of them look just fine and dry but still a miss. Is there anything else that could be wrong to make it do this? What would help me clear this all up? Should i go see if any codes come up? SEL is always on due to a bad connection to my speed senser but who needs to know how fast your going. lol either way what should i do any help is very much appreciated.
Old Jul 9, 2009 | 10:08 AM
ebxgsxr's Avatar
ebxgsxr
recheck the codes. if it's misfiring, it should set a code. it may tell you which cylinder is misfiring. it may just be time to repalce that bad coil.
Old Jul 10, 2009 | 04:17 PM
Killzone001
well rechecked codes nothing but speed senser so... i guess time to start taking off coils and testing.
Old Jul 10, 2009 | 04:50 PM
Oldtrucknut7077's Avatar
Oldtrucknut7077
Make sure there is no water in the holes, this will also cause a miss. I just looked on ebay and there are some cops on there for about 70 plus shipping (if you have the 5.4). I replaced mine on my Expy and they cured my miss problem. Thats been 2 years ago and still no problems. If you have the 4.6, it will probably be best to replace the coil packs. Good luck!
Old Jul 10, 2009 | 10:13 PM
azwarrior's Avatar
azwarrior
indeed i would take off all the cops then blow out the holes with an air hose.how old are the rubber boots on your truck if they are old and cracked that can cause a miss i seen them at autozone for 3.99 each on sale right now so i told checkers for 5 percent more off.. hey every bit helps these days and if you buy new coils you have to buy the boots separate anyways...
Old Jul 10, 2009 | 10:14 PM
azwarrior's Avatar
azwarrior
also i recently washed my motor and has the same problem it took a little over a week to dry out completely so no worries yet
Old Jul 11, 2009 | 12:50 AM
Killzone001
well mine is the 4.6L with the cops. and rubber boots are you talking about exactly? Tomorrow i start pulling the cops of and testing them
Old Jul 11, 2009 | 04:48 PM
azwarrior's Avatar
azwarrior
yes i have the 4.6 also you can check the thread i had on here titled how do you check the coil packs there is a rubber boot connected the the bottom of the coil pack these go back and crack you can check it by simply squeezing it if it cracks when you squeeze it then they need to be replaced also whenever you replace the spark plugs its good to replace them.
Old Jul 11, 2009 | 04:59 PM
AnaJu's Avatar
AnaJu
mine too
xxxxxxxxxxxx
Old Jul 12, 2009 | 04:58 PM
Killzone001
okay so i started taking them off and testing today i have done six the last two on the drivers side is a PITA but 4 have been weak but not bad and one did have water down in the spark plug well. I had one boot the pretty much fell apart when i pulled it out the other has some cracks. but imma see if it will run close to right with that water cleaned out and if it will ill have to limp it along till i can get $400+ for all new packs and boots and die-electric grease. but we will see ill let ya know how it goes. long live the tough ol ford
Old Jul 12, 2009 | 06:32 PM
galaxie641's Avatar
galaxie641
You can get 8 COP's with boots on ebay as stated above for $100 or less. Might as well replace them all, once they get wet they are more or less done for.
Old Jul 12, 2009 | 06:51 PM
nathan19's Avatar
nathan19
definitely a good idea... and it's pretty cheap to do
Old Jul 12, 2009 | 09:40 PM
Killzone001
yea i looked and found some accel ones from brothers performance they are for the 4.6L 2v mustangs which is the same motor lol so yea and they only want like $200 for them and they are a perfomance thing. Well more spark energy anyways. but yea does that sound like a good deal to yall?
Old Jul 16, 2009 | 03:09 PM
azwarrior's Avatar
azwarrior
Originally Posted by PerfDistIgnition
Our SOS-Sultans Of Spark will NOT arc. We can assure you of quality coils, just like we do with our D.U.I. Distributors.
http://www.performancedistributors.com/soscoils.htm
And you can buy one at a time if you only want to replace the bad coil(s).
in my thread this guy wrote this i dunno if its a great deal bbut it sounds good might wanna see if they have the same out put as the ones you were looking at
Old Jul 21, 2009 | 12:08 AM
Killzone001
hey anyone else ever hear or try those coil packs
