you are right I meant transfer case, As for what is spec'd the rear ends spec'd at 75w 90 I thought there was a TSB out that said to put the heavier weight in to 75w 140....as for the tranny and transfer case, the last time I had a manual was a 97 and the general consensus on that forum with the ZF5 was that the tranny ran better and shifted better with a 5w 40 motor oil in it than the mercon atf that was called for......I am going to put the atf in the tranny unless recomended otherwise
