Oil cooler replacement?
Old Jul 8, 2009 | 11:14 PM
gmyers's Avatar
gmyers
I have a 2004 SD with 125000 miles. Had the heads rebuilt, head studs installed and new EGR valve. Now while towing trailer, the cooling fan runs almost continuous. I then installed a coolant filter. No change. I now think oil cooler may be the problem. How can I test it to know for sure with out tearing the motor down?
Old Jul 9, 2009 | 05:10 AM
HeavyAssault's Avatar
HeavyAssault
Check the coolant temp and oil temp. They should be within 10* of each other, I can't say where you need to pull the readings.
