Sponsored by: Real Truck
funky steering/4x4 problem
Old Jul 8, 2009 | 04:21 PM
995.4SD's Avatar
995.4SD
I have been having a problem with the steering and I have narrowed it down to either the hubs and/or the front axle u-joints. My problem is the steering is extremely jerky, feels like a binding. It will be tough to move the steering wheel, then it will break free and turn fine. I thought it might be the old stabilizer shocks so I took them off, but they are smooth. So after thinking about it I noticed the hubs have been getting a little noisy, and rattling, so I took them off and went out for a drive. Every symptom went away. So now the only thing I can think that these being bad would maybe be locking and I also have bad axle ujoints which is the cause of the jerking. The steering has gotten so bad I do not drive it with the hubs installed, it's way too dangerous with them in. Am I on the right track?
Old Jul 9, 2009 | 08:14 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
One thought. If the u-joints were bad, you'd have stiff steering even with the hubs unlocked if the u-joint is in the right angle.
Turn the u-joint so one set of cups are straight up and down, and test the steering - best with the wheels off the ground. Then, turn the u-joint 90 degrees, and test again. This will tell you if the u-joints are bad. Although, if they bind up randomly, this test won't help
Old Jul 9, 2009 | 01:47 PM
995.4SD's Avatar
995.4SD
Ya, it's all random...the only thing I have done to correct any issues were to pull the hubs. I will start with some warn hubs and go from there
Old Jul 11, 2009 | 06:03 PM
muusu's Avatar
muusu
Your U-joints are probably seized. I went through this not to long ago and it took a long time to figure it out. My u-joints were seized only in one direction so worked fine sometimes. One way to check is to physically turn your u-joint until it is at 45 degrees and then have someone turn the steering wheel. The joint should snap around to the free side allowing normal steering.
Hope that helps if you haven't already got it figured out.
Old Jul 11, 2009 | 09:24 PM
FireMe's Avatar
FireMe
With the truck parked, turn the steering wheel all the way one way (doesn't matter which way.) Jack up one wheel, lock the hub, and spin the tire. A badly seized u-joint will be very apparent. Try both sides, of course.
Literally takes two minutes to do this check.
