Proportioning valve
Old Jul 8, 2009 | 08:55 AM
twise's Avatar
twise
Proportioning valve
Hi, I have a proportioning valve from a 79 Ford F100 and am not sure which end is which. there is a nut on one end for adjusting and am not sure which end it goes (front or rear). I am assuming the nut end is for the rear brakes. I just don't want to install and re-install. If anyone knows I would appreciate any advice. It might be called a combination valve also, it does have a switch in the middle top portion which I believe is a low fluid warning switch but not sure on that either. Thanks
Old Jul 8, 2009 | 11:08 AM
CharlieLed's Avatar
CharlieLed
This should help...
http://www.piratejack.net/Download-d...tructions.html
Old Jul 8, 2009 | 11:13 AM
twise's Avatar
twise
thanks. anything is appreciated.
Old Jul 8, 2009 | 09:12 PM
49fordpickumup's Avatar
49fordpickumup
Google proportioning valve or combination valve and it will tell how and why they operate within the brake system.Chuck
