Mass air help
Old Jul 7, 2009 | 09:32 AM
johnnyrocket's Avatar
johnnyrocket
Mass air help
I have a set of 24lb injectors and a 90 mm mass air that came off my mustang. i was thinking of building the motor in the bronco and swapping to a mass air conversion. How hard is it to do and could some one help me get started in the right direction. It's a 1993 5.8 4x4 e40d Eiddie Bauer
Old Jul 7, 2009 | 12:26 PM
Kemicalburns's Avatar
Kemicalburns
19lb injectors will support 300-350hp before requiring more fuel so take that into consideration.
now the easiest and most plug and play setup would be to locate a 93-95 5.0/e4od mass air bronco and take the entire wiring harness, injector harness and mass air harness, meter and airbox along with intake tubes. also grab the computer, it will run the 5.8 good and should only require minor tuning to get spot on but probably wouldnt be necessary.
