General Diesel Discussion
Why do heavier trucks use Less HP....
Old Jul 25, 2009 | 02:40 PM
orng1's Avatar
orng1
We had a customer with a 5.9L cummings in a 26' delivery box truck. I thought it drove pretty good considering the size and weight of the truck. My boss repaired the block. He welded it in 3 spots, a few months later it cracked the block again in 2 other spots. We put a new block in and he had the pump turned down a little bit. He was talking about doing a 466 swap if it breaks again.
Old Jul 26, 2009 | 02:20 AM
DeepRoots's Avatar
DeepRoots
I work on marine diesels and the rating is different still.
On this tug I'm now now, we have 16v149 Detroit diesels.
16 cylinders, V block, 149 cubes per cylinder.
and yet at 2000rpms we only make 900hp per cylinder? that is 2384 cubic inches per engine (we have two, 1800hp boat)
I used to be on another boat with EMD 16 645's. V16 645 cubes per cylinder.... it only made 1500hp.
yes, thats all, but they also last 30,000hours with minimal problems.... the occasional power pack, the occasional injector. On a tow, this engine may be making full power for 200-300hours straight without being shutdown.
Now a cummins 5.9 with heavy mods can make 900hp, or so I'm told (never seen on a dyno). I would love to see a 5.9 towing a barge vs a 16v149..... The cummins would be a puddle of steel before the Detroits scheduled oil change. I've only ever seen the cummins 5.9 to power a generator out here. The markings on the side claimed 115hp raw water cooled, 95hp keel cooled
Old Jul 26, 2009 | 03:44 AM
Kenworth's Avatar
Kenworth
The 5.9 Cummins is a grossly over rated engine. It isn't designed for high horsepower (sustained). You may get 900hp out of it but that is for what 1 minute or less.
The only reason why you see a 5.9 Cummins in a medium duty truck is when the truck was new the 5.9 was the cheapest engine option. It is the only reason why you see one in a medium duty. A gas engine actually does better in a medium duty over the 5.9.
Old Jul 26, 2009 | 04:01 AM
DeepRoots's Avatar
DeepRoots
oops, can't edit this, was a mistake, 900hp was for the whole engine.
Drew
Old Jul 26, 2009 | 07:10 AM
Tom's Avatar
Tom
Very interesting post, DeepRoots
Not difficult to see how the last that long, though. 149 CI x 16 cylinders = 2384 CI...which converted into liters would be just greater than 39 liters.
So, 900HP/39 liters = 23 HP per liter. If a 6.0L PSD made that mush specific output, you'd be seeing somewhere around 138 gross HP. And it'd probably last longer than it's driver.
Just curious now, is that big marine engine turbocharged or N/A?
Old Jul 26, 2009 | 11:20 AM
DeepRoots's Avatar
DeepRoots
they are NA.... well obviously being 2strokes they are supercharged tho. Still drink 50gallons an hour or better at full power.
Lead Head
6.2L V8
27
Jun 20, 2018 01:49 PM
reluctantfiver
Aug 17, 2009 05:19 PM
MountainHound
Ford vs The Competition
86
Jul 23, 2004 01:11 PM
bigbluebronco43
2004 - 2008 F150
31
Nov 2, 2003 01:12 PM
