A/C Compressor steady running ?
Old Jul 7, 2009 | 08:10 AM
harry whooo's Avatar
harry whooo
The problem I have is that the compressor is at .025 clearence with the A/C clutch. The compressor runs all the time. Does not switch off and on like it's suppose to. It does shut off when you turn the A/C off, but other than that, it runs all the time. I added some freon, and then it started to shut off and on constantly. It was up to around 60 lbs of pressure. I released some freon and that stopped. The coldest I can get it to blow is 60 degrees. Compressor runs all the time. Any ideas? I have installed the shut-off valve on the heater hose which did help some, but that obviously doesn't address the compressor problem.
