transmission swap
Old Jul 7, 2009 | 07:25 AM
snowmanbs's Avatar
snowmanbs
transmission swap
i was wondering if it is possible to use a automatic transmission from a 1989 or 1990 grand marquis and bolt it up to a I-300 that had a standard transmission .
thanks for any help you guys can give
Old Jul 7, 2009 | 09:44 AM
Franklin2's Avatar
Franklin2
If the later tranny is a electronic one, no. If the later tranny didn't have a speedo, cable, then you have to deal with that too. If the later tranny was not electronic, and did have a speedo connection, then you have to worry about the TV cable hook-up to your carb to make the tranny shift right.
