What is this?
Old Jul 6, 2009 | 11:16 PM
wreckinball's Avatar
wreckinball
What is this?
I seems to be leaking a lot of oil and with the pics it has some description and drawings to show where it is. Essentially it is right under the oil pump.
Below are the pics so let me know if possible.
http://memberfiles.freewebs.com/75/3...HAT%20PART.JPG
http://memberfiles.freewebs.com/75/3...AT%20PART2.JPG
http://chiefwhitaker.webs.com/apps/p...otoid=43402002
Old Jul 6, 2009 | 11:27 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Can we change a couple names on the pictures?
First picture the oil pump is a vacuum pump.
Thing in question, inlet and outlet is your fuel lift pump, same as the fuel pump on a gasoline engine.
Some people/books call it a transfer pump, but it lifts/transfers fuel from the tanks to the injection pump.
Picture two, left port is from the tank selector valve, right port is out to the fuel filter.
And again in picture three, thing is under here, thing is lift pump, here is vacuum pump.
LMAO
Sorry, I work with 6 Smart A kind of guys and we were all together today.
But I had fun, can you tell?
LMAO again.
Old Jul 6, 2009 | 11:50 PM
idi king's Avatar
idi king
if the oil is leaking from the fuel pump then change the pump they do get lubricated with oil and have a diaphram that seperates the oil and it ruptures and leaks oil
Old Jul 7, 2009 | 12:18 AM
wreckinball
LMAO
LMAO again.
Pkay there smart A$$! So if nothing is connected, will it just leak or is ot ok like it is, the rear or second tank is not connected. It could be that there is another seal leaking and it is just getting on there bit it looks to be coming out of there. Would this need to be connected? Just trying to figure out why it isnt hooked up..
p.s. did you see my message to you about the Stanadyne IP? Can you decipher the numbers on the IP to what year it goes to? and no smart a$$ answers!!! hahaha
Old Jul 7, 2009 | 03:08 PM
wreckinball
So in the picture it is a "fuel" lift pump? if it isnt hooked up where would the lit pump be? frame mounted like later ones? I havent looked all over yet but if they just ook that one out of the equation, how can i shut it off because there is oil leaking from it, i suspect anyway. Can i take it off and bolt up a plate on there? Help please fellas!
Old Jul 7, 2009 | 09:20 PM
Dave Sponaugle
All IDI trucks used that lift pump from the factory.
Frame mounted would be an electric pump installed by a previous owner.
My guess is either air intrusion or a ruptured diaphram in the stock pump is why it is not hooked up.
Big block Chevy fuel pump block off plate will fit to close off the hole.
AS for the IP number info, I seem to have lost a bunch of my info text files in my hard drive swap process.
I am not sure exactly where they are, or if I have accidently deleted them.
I am bummed right now about all I can't find.
Old Jul 7, 2009 | 10:17 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Dave,
Not to get off topic, but you haven't wiped out your old hard drive yet have you??
-Enjoy
fh : )_~
Old Jul 8, 2009 | 12:18 AM
wreckinball
dont sweat about getting off of topic, i am bad about that. I just need to know where is the best place to get the "plate" for blocking the opening off. Is this PLATE what you are talking about?
Old Jul 8, 2009 | 12:37 AM
rupejosh's Avatar
rupejosh
just go to any parts store and get a fuel pump block off plate for a big block chevy.they are around $5.and yes thats the plate
Old Jul 8, 2009 | 12:52 AM
wreckinball
very nice and thanks, i am off to the parts store tomorrow! hopefully they will be in stock!
Old Jul 8, 2009 | 09:14 PM
Dave Sponaugle
On the hard drive...
Sorta
I am finding the files, slowly.
Where I am at exactly is after 20 plus years of records on computers, many failed hard drives and computer upgrades with information copied from one drive to the next.
I have files in to many places, and way to many duplicate files with "almost" the same information.
So right now I have moved everything from three IDE drives to an external USB drive, 500 gigs over 75% full.
New SATA 500 gig internal drive, almost empty.
Before I move anything, documents that are almost the same info are combined.
Web addresses that no longer work, deleted.
Web addresses that still work, sorted with a better system so I can find them easier.
Just a very long process, but will be much easier when I am done.
Where I am right now, wanna guess how many files I have to look through to find one in 350 gigs of data that is not sorted yet?
Sorry for the off topic stuff, but now everyone will know why I probably seem a little off with my answers if I can't remember the info in my head.
On the bright side,
Injection Pump / Injector Application
Year______________________________________Pump____ ______Injector
1993-1994____7.3L Turbo___F or E, M/T________DB2-5070_______LJCK01102 or 30406 or G
1993-1994____7.3L Turbo___F or E, A/T________DB2-5069_______LJCK01102 or 30406 or G
1992.5-1994__7.3L_________F or E, M/T________DB2-5028_______LJCK01101 or 29455 or E
1992.5-1994__7.3L_________F or E, A/T________DB2-5013_______LJCK01101 or 29455 or E
1990-1992____7.3L_________F or E, M/T_______DB2-4821________6760301___________B,BB,C,D
1990-1992____7.3L_________F or E, E4OD______DB2-4817________6760301___________B,BB,C,D
1988-1989____7.3L_________F or E, C6 or M/T___DB2-4812_______6760301___________B,BB,C,D
1988-1989____7.3L_________F or E, E4OD_______DB2-4808_______6760301___________B,BB,C,D
1987_________6.9L_________F , 5 speed______DB2-4746_______6760301___________B,BB,C,D
1984-1987____6.9L_________F or E, C6 or 4 speed_DB2-4541______6760301___________B,BB,C,D
1983_________6.9L_________F or E,_____________DB2-4102________________________A or AA
Old Jul 8, 2009 | 11:02 PM
Festus Hagen
Methanoholic
Yup, Know what you mean, been there done that way to many times, it's a forever ending process.
Used to make a living doing exactly that... Cleaning, Organizing Corporate drives for some pretty huge companies. Data Management & Storage!
Thats why I asked, I've done a lot of recovery.
Yea, ... Uh Huh! Yur funny, Like ANYONE could have a clue...
I'll trade you any time ...
We have about 5TB of data scattered across about 6.5TB of drives! (Our Server, 6*ST31500341AS)
Have fun organizing it, It's imperative it's maintained in it's use!
On the bright side,
YES! Thank you for the bright side! Awesome tidbit of info.
-Enjoy
fh : )_~
Old Jul 9, 2009 | 12:10 PM
wreckinball
wow that is awesome i saw a format like that for all of the gm vehicles when googling but nothing for ford. Thanks bro!!! I believe we have an 89 now. Could be the 4817 but i am pretty sure it is the 4812. hard to make out.
