A/C questions...
Old Jul 6, 2009 | 11:09 PM
RocketMonkey28's Avatar
RocketMonkey28
A/C questions...
I did a search, but didn't turn anything up. I've a crew cab with a 460 that the air doesn't work. I just got the truck, so I don't know much about it. It seems to be charged, or at least it won't take any freon, but the compressor sort of cycles on and off. The reading goes from low to hi in a matter of seconds when the compressor comes on. Could this be a clogged expansion valve? Or an orifice problem? Looks like maybe the compressor goes out out on hi head pressure? I haven't picked up a manual for it yet, guess I'd better. I was hoping someone here has experience this and it's a simple solution.
Thanks very much!!!!!!!!!!
Al
Old Jul 7, 2009 | 07:08 AM
Lazy K's Avatar
Lazy K
You should post this on the Heating and Cooling page, there A/C experts there like you wouldn`t believe.
Old Jul 7, 2009 | 07:56 AM
subford's Avatar
subford
Sounds like you are hooked to the high side and need to be hooked to the low side.
And it sounds like you are low on freon or what ever you truck takes.
Old Jul 7, 2009 | 08:13 AM
choochoof150's Avatar
choochoof150
If your clutch keeps kicking on and off a bunch you could have a clogged orfice tube. That would be from your compressor going to pot. Check your low side and watch what it reads. You could have a bad compressor.
