Sponsored by: Real Truck
ABS Light...questions?
Old Jul 6, 2009 | 09:16 PM
Screamin T/A's Avatar
Screamin T/A
Hello, I've read through multiple threads, and tomorrow I will pull my rear end sensor and clean/replace and see if that makes my ABS Light go out. BUT, I have never read anywhere about my issue. I just got finished cleaning my truck, then went on the highway around 75. This car in front of me stomped on his brakes (still don't know why??) and therefore I stomped on mine. The truck pulled hard to the left, and the light went on. After that all was fine, and since then the light comes on when I start the truck, as soon as the idles gets down even before I start moving.Fuses are all fine, the 10amp and the two 60amp. Any other thoughts on this? Do you think it could be that rear sensor? By the way, the truck is a '05 F350 HD Diesel...thanks in advance, I want to get this fixed I hate little lights!!!
Old Jul 7, 2009 | 11:16 AM
Screamin T/A
Anyone? Also, I forgot to mention that when i stomped on the brakes, the pedal acted as if the ABS was kicked on, with it surging......please help!!
Old Jul 7, 2009 | 05:21 PM
Screamin T/A
Ok, so I got the truck scanned, and it said that there was no input from the right front sensor. My question is how hard is this to replace? How do I do it? Also, I have heard that the 05+ wheel bearings are different, what is different about them versus earlier ones if I had to replace the hubs ? thanks
