gear swap.
Old Jul 6, 2009 | 08:52 PM
Muddedprairie's Avatar
Muddedprairie
gear swap.
i do belive i am going to change the gears in my truck from the 3.73's that are in it to 4.10's just to help the truck a little better on the hills with the weight i tow. Plus turning the tires i do. My question is where did you guys get the gears from what was the cost for you to buy them? I will be doing the work myself. and did it make a big difference in your truck?
mark
Old Jul 6, 2009 | 10:06 PM
Deluxe05's Avatar
Deluxe05
Having spent years & years in four-wheeling communities, I would strongly suggest Randy's Ring & Pinion. They are extremely knowledgeable, very competitive, and have an excellent track record. When ordering your ring & pinion sets, do not forget to order master install kits. After all, it is much easier to replace some of those parts while you have everything apart.
Old Jul 7, 2009 | 03:32 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
4.56 or don't waste your time IMO
alot of guys have done the 4.56 swap...especially those running 35" tires like you.
most report they regained their power to back to stock levels, and that their lower RPM mileage came back up as well.
besides, 4.56 gears will really help you when hauling that trailer & your 4-wheelers. You will see a difference with 4.10 gears...but not alot.
Old Jul 7, 2009 | 03:40 AM
Monsta's Avatar
Monsta
Sit. Stay.
I'd like to concur. 4.10s w/35s are not worth the cost of the upgrade.
Old Jul 7, 2009 | 04:19 AM
6CylBill's Avatar
6CylBill
I'll third that. 4.56. My ring and pinion and locker are all Powertrax, ordered thru Jegs.
Old Jul 7, 2009 | 11:29 AM
Muddedprairie
Thank you guys very much for the info i'll look into this and let you all know the outcome.
Mark
Old Jul 7, 2009 | 02:10 PM
Fishin76's Avatar
Fishin76
Don't forget to order the set for the front too!
Old Jul 7, 2009 | 03:18 PM
6CylBill's Avatar
6CylBill
Might be worth looking into a locker, too, while you're at it.
bmacky14
Feb 28, 2010 05:59 PM
ford-nut
Apr 22, 2008 11:50 AM
just1me
Jun 19, 2006 07:20 PM
mooktank
Nov 20, 2002 05:40 PM
