Bronco II Ford Bronco II
Starter won't stop
Old Jul 6, 2009 | 01:54 PM
johnnybronco's Avatar
johnnybronco
Starter won't stop
I could use some help figuring out what I've done to my 1990 B2. I was replacing the positive battery cable. It slipped out of my hand at the starter relay (the one that bolts onto the chassis, inside of the hood-passenger side ) and made contact with the other terminal on the relay. The starter kicked on, the battery cable got super hot and a small fire started at the relay. After I got the situation under control, I replaced the relay and everything was fine for a few days. Then I noticed the battery was draining yesterday. Then when I tried to start it today, it seemed like it didn't have enough juice in the battery to start- just kinda went rrrr, rrrr, rrrr without catching. When I turned the key off - it just kept trying to start - rrrr, rrrr, rrrrr....for a few minutes until the battery died. I put a fresh battery in and it has started and run just fine for the last 4 hours. Any ideas as to why this happened? My guess is something got fried when the fire happened and is now grounding out and making contact when it shouldn't. I just don't know all the parts involved and what to look for.
Old Jul 6, 2009 | 06:52 PM
Chucky Babe's Avatar
Chucky Babe
test your battery you might have cooked it
Old Jul 7, 2009 | 07:31 AM
tommyleea's Avatar
tommyleea
Take a test light, and test out the connections at your solenoid. Key on, on off. Obviously, you shouldn't have any power to the starter with the key off, so maybe your ignition switch is going south. Shoot some wires.
TommyJ
Old Jul 12, 2009 | 06:40 PM
mudslinging79's Avatar
mudslinging79
had the same problem once, was the solonoid. smacked it with a screwdriver handle to un freeze it till it was replaced, bout 10 bucks new.
Old Jul 12, 2009 | 06:59 PM
regulate34's Avatar
regulate34
yeah it sounds like the starter solonoid for sure
its a cheep fix
Old Jul 12, 2009 | 07:24 PM
mudslinging79
just dont over tighten the connection terminals, body is only made of plastic...
Old Jul 21, 2009 | 03:53 PM
greenbullitt's Avatar
greenbullitt
REPLACE THE SOLENOID FIRST.running it that hard could have cooked the battery or starter. if it happens again have the starter checked.
taylerallen6
1997 - 2003 F150
Jun 21, 2016 06:45 PM
Mab1957
Oct 21, 2015 01:25 PM
1965tontruck
Electrical Systems/Wiring
May 25, 2010 05:24 AM
rrrr2
6.4L Power Stroke Diesel
75
Nov 4, 2008 08:29 PM
aguylookingforadvice
23
Apr 19, 2006 07:27 AM
