Inner door handles don't work...
It's odd that none of the inside handles work since the fronts are cable controlled (which DO tend to break) and the rears are controlled by a solid round rod. Do the rears have the "Child Safety" levers that may be flipped? I don't see any references to them in the owners manual.( which, if you don't have one, you can download from the FORD site https://www.fleet.ford.com/maintenan...ls/results.asp )
(#7 in both illustrations is the link between the handle and the lock)
Item Part Number Description
1 20124 Front Door
2 21852 Front Door Latch Push Button Rod
3 22152 Front Door Latch Actuating Rod
4 22134 Front Door Latch Control Cylinder Rod
5 218A42 Power Door Lock Actuator
6 W701566-S417 Rivet
7 21818 Front Door Latch Remote Control and Link
8 389760-S Clip
9 386656-S Bushing
10 219A36 Retainer
11 391564-S Bushing
12 N800510-S100 Screw and Washer
13 N623332-S100 Nut
One source is site sponsor http://www.trademotion.com/partlocat...layCatalogid=0
1 264A80 Rear Door Latch Push Button Rod
2 26408 Rear Door Latch Control Rod Link
3 26412 Rear Door Latch
4 — Rear Door Latch Remote Actuator Link (Part of 26594)
5 26594 Rear Door Electric Latch Actuator
6 388047-S101 Rivet
7 26442 Rear Door Latch Remote Control Link
8 26592 Rear Door Latch Remote Control Support Bracket
9 385189-S100 Rivet
10 1021818 Rear Door Latch Remote Control and Link
11 22600 Inside Door Handle
12 26448 Rear Door Latch Bellcrank
13 26596 Rear Door Latch Actuating Rod
14 386656-S Bushing
15 389760-S Clip
16 N800527-S100 Screw and Washer Assy
17 N623332-S100 Spring Nut
1 20124 Front Door
8 389760-S Clip
9 386656-S Bushing
10 219A36 Retainer
11 391564-S Bushing
13 N623332-S100 Nut
6 388047-S101 Rivet
9 385189-S100 Rivet
14 386656-S Bushing
15 389760-S Clip
cabloom300
04-10-2017 11:51 AM
Lancester
10-07-2015 07:43 PM
Mocha Joe
06-26-2013 08:28 PM
Adamjr
09-22-2009 06:25 PM
