80 F100 Brake Problems
Old Jul 5, 2009 | 07:52 PM
stangfan78's Avatar
stangfan78
I have a 80 F100 that I just got running again after sitting for about 5 years. When I stepped on the brake the pedal went to the floor and I heard the sound of air being pushed out. I checked the cylinder and the fluid was low so I filled it up. I then continued to step on the pedal but it kept going to the floor and I heard the same sound. I checked the fluid and the level didn't go down. I had the pedal on my 93 F150 go to the floor before but I found a broken brake line. I don't see where it may be leaking on the F100 so I think it may be the booster. Anyone have any suggestions on what I should check?
Old Jul 5, 2009 | 11:05 PM
Franklin2's Avatar
Franklin2
If you have a good pedal with the engine off, it indeed may be the booster.
Old Jul 5, 2009 | 11:13 PM
6fifty_f1fifty's Avatar
6fifty_f1fifty
I had a similar problem where I could hear an air sucking sound when the brake wasn't being pushed and it ended up being the booster. I would try to bleed the brakes, you could have a major bubble in there somewhere, and check each of the wheel cylinders for leakage, if that doesn't work then replace the booster.
The one I had a problem on, looked like the booster was original (rusted to hell). Replaced it everything worked great after... real easy, remove two bolts from master cylinder (you don't have to disconnect any brake lines, just find a way to support the MC so the brake lines don't get bent) then there are four bolts holding the booster to the fire wall and a clip holding the brake pedal to the actuator... really easy to swap and not too expensive, unless you have someone else do it.
Old Jul 6, 2009 | 08:33 AM
stangfan78's Avatar
stangfan78
Sounds easy enough, are those 4 bolts under the dash or accessible under the hood?
Old Jul 6, 2009 | 04:52 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
The Four bolts holding the booster to the firewall are inside the cab.
You also have to disconnect the brake pedal and brake light switch.
As said above, not too difficult.
Also with the booster off, check the firewall for cracks. The 1980/ early 81 was factory recalled for the possibility of severe cracks to the firewall due to flexing from the brake booster and/or clutch. A reinforcement repair kit was avaliable to fix the problem. If it has this reinforcement kit, leave it on. If it has cracks, they will need to be repaired. Do not know if they still make the kits to fix the problem. Probably not though.
If the fluid is black and dirty, I'd recommend a brake line flush, with new fluid.
Also of note, Brake warning lamp on? Porpotioning valve might be out of center, shutting off the brake fluid to one axle.
Old Jul 6, 2009 | 07:13 PM
stangfan78's Avatar
stangfan78
I did what Franklin said and tried the brake with the engine off and it was tight. I then started the engine and the pedal went to the floor.
Old Jul 6, 2009 | 07:21 PM
81-F-150-Explorer
I agree with Franklin, most likely brake booster.
Eddillard79
Nov 24, 2014 07:13 AM
PatsPOS
Apr 19, 2010 06:21 AM
DeanBob
Oct 23, 2007 09:11 AM
gbaumgar
Jan 14, 2004 08:23 AM
