F150 Last Forever?
F150 Last Forever?
Hey guys i bought a 06 F150 a couple of months back and i plan on deeping it for as long as i can. With that in mind, what should i do to it to make it as long lasting as possible? Any weak point i need to address or anything like that? The truck has dual exhaust and an aem dryflow filter in the stock intake. I also have an SCT X3 programmer from mike at 5 Star Tuning. Any thing else i need to do to my truck to extend longevity?
change your oil every 3-5,000 miles and keep that air filter clean
probaby wouldn't hurt to drive it nicely either...but that isn't fun
just take care of the maintenance aspect. I've had plenty of 90's F-150's go well past 100,000 miles. My record to date is 283,000 miles in a Bronco (covered F-150 shortbed).
Regular maintenance, wash and wax regularly, and don't drive beyond what it was designed for. Use only Motorcraft oil filters. Avoid hard acceleration from a stand still and don't over heat the engine or transmission and it'll last you a long time. I have had many Ford gas engine trucks go well beyond 100,000 miles with no problems, even late 70's F series trucks. And don't neglect the cooling system, either. Coolant needs to be changed at the recommended intervals also, especially with aluminum parts on the engine and cooling system.
Besides low revs and low temps, my experience is that the interior wears out long before a well-tended engine. This is based on owning two F150s for 12 years each. So I'd suggest:
- Steering wheel cover
- Seat covers
- Floor covers - both my high-mileage trucks had holes in the floor (one carpet, one vinyl) at the end
- Dash cover if you park in the sun
- Windshield covers are good long term to avoid other sun damage.
If you take reasonable care of the engine, what fails over time are switches. Power windows and power door locks. Clutch safety starter interlock. Et cetera.
So, check back with us in ten years and tell us how it goes. Good luck,
- Seat covers
- Seat covers
- Seat covers
I had a 94 b4 i bought my 06. The only bad thing was it was neglected by the previous owner. Sine im the second owner of my 06 and it has 41,000 im going to try to do like you and make it last a very long time. My 94 had 192,000 when i traded it in and had a rear main leak and a oil pan leak, craked dash pad, and sloppy steering. I bought it at 15x,xxx miles
- Seat covers
- Seat covers
Loooooooooow Revs...
On my 300 I-6s, I rarely took it over 2200 RPM, and usually never over 2000.
I had no tachometer in either of my recent body style trucks, so this is a guess. But I think I'm occasionally reaching 3000 when accellerating on an onramp with my current V6. I think it spends most of the time in 1600-1800. It would be good to track it, I guess.
Good luck,
Good luck,
