My truck is starting to something similar. I have had wierd issues just recently when pulling away from a stop where it feels like the truck hesitates for about 2-3sec then goes. Almost like it is dropping into a very low gear initially then hops into the right gear and goes. My wife also said she noticed the other day the Overdrive light was flickering. We have also had issues when you put the truck in park that is will accelerate momentarily then go back to normal. Got the codes read today, is did have a SES, and it threw a p0720 and P0670. So from what i'm getting p0720 is output shaft sensor, so guess i've got to find one of those, and then figure out where the hell it is. Hope that helps.
I found the leak, it's the drivers door about half way down. The water is only coming in at the floor level so it isn't getting any of the electrics wet. So that has nothing to do with the problem it seams.
I took the truck in this morning to have the codes read but there are no codes in the memory . The weird thing is that the o/d light was flashing (none of the other problem tho) half way to work this morning too. I'm going to take the truck back again if the light is flashing when I'm near the shop and see if that makes any difference.
At this point, I really don't know what else to do. I just I'll keep driving it and keep an eye things.
