engine wont start help plz!!!
Old Jul 2, 2009 | 07:40 PM
packer_1's Avatar
packer_1
i took the motor and tranny out and replaced some seals and when i put it back in now it wont start and its cranking over hard as hell with brand new batterries new starter and chargers on both batteries what else should i be looking for or what am i doing wrong
Old Jul 2, 2009 | 08:38 PM
F350-6's Avatar
F350-6
Welcome to FTE. What seals did you replace? Do you have a scanner where you can monitor live data while cranking? That would make life easier.
To start, make sure you didn't forget to plug something back in. Check the fuses, check the engine oil level and oil level in the HPOP reservoir. Can you hear the fuel pump come on when the key is turned to the on position? WTS light come on & go off like normal with the key?
Old Jul 2, 2009 | 08:39 PM
mudmaker's Avatar
mudmaker
Can't help ya, but i'll give ya bump.
BTW, welcome to FTE!
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Do you know how to check the oil level in the HPOP reservoir? It should be 3/4 - 1" from completely full. There's a drain valve that keeps it from going 100% full I believe.
Do you have fuel in the fuel bowl?
Have you checked all your harness connections & sensor connections?
Old Jul 2, 2009 | 09:23 PM
riverrat41's Avatar
riverrat41
Welcome to a great place!These folks will die trying to help you out.Keep in touch with them when they ask for things.
Old Jul 4, 2009 | 03:00 PM
packer_1's Avatar
packer_1
i replaced the for plugs and seals one on each end of both heads and i didnt have the reservoir full of oil. when i got it full and primed it not only turned over better but it started. but now i gotta take it back out becuase the tranny isnt catching so im going to get a new torque converter. thanx guys for the help
