Unmolested 76 exaust ?
Old Jun 30, 2009 | 08:49 PM
frigerator's Avatar
frigerator
My 76 CC 390 has only 80k miles on it. It has the factory pipe and the ford stamped muffler. Everything is solid. I like the way they bent the pipe back then, I have never seen bends like that before. My ? is. I have a 78 460 SC that I want to cut the exaust off of and put on the 76. It has two glass packs and I like the sound. The 76 is so quiet that you can't tell if it's running at an idle.
Old Jun 30, 2009 | 09:03 PM
peganit2's Avatar
peganit2
If the question was will the exhaust from the 460 SCS fit on the other truck, the answer is not without modification.
Nice truck!
Old Jun 30, 2009 | 11:38 PM
Sayer Lane's Avatar
Sayer Lane
understand that you like the way they used to bend the pipe, but why not take it to your local muffler shop and get custom pipes. if that cant be done for certain reasons then the pipes probably will not fit w/o modifications.
Old Jun 30, 2009 | 11:53 PM
frigerator's Avatar
frigerator
Thanks for the compliment peganit2. I was just curious if there was a need for the factory stuff by someone wanting to go all orig. I was going to cut the exaust out of the 78 and piece into the 76. Then put the stock muffler on the 78.
Old Jul 1, 2009 | 12:11 AM
Jermafenser's Avatar
Jermafenser
Why do you want to change it if it isn't giving you trouble?
Old Jul 1, 2009 | 08:29 PM
frigerator's Avatar
frigerator
I want a little rumble when I give it gas and to releave some back pressure.
Old Jul 1, 2009 | 08:38 PM
Sayer Lane's Avatar
Sayer Lane
i've got true duals with glasspacks and i know the sound you want. but trust me it would be a lot easier to take it to a muffler shop. i know (i did my own exhaust work)
