Has anyone used the Altman door latches that MF sells, are they as easy to install as they say? does the door lock actaully work? do the doors work/align better after install and lastly do anyone have pictures of an install I have some on the way which I should get at the end of the week.
Thanks in advance.
Also has anyone used Astro van seats for a 53-55 again any pictures.
I used altman latches on my truck - they fit very well and were quite easy to install. They do work with the stock locks etc (I put a set of NOS locks on at the same time).
I had to file out the mount holes a tiny bit on the striker for a better fit but thats because I had to make up some new backing plates behind the door piller (and I'm not as accurate as a cnc machine!!).
Just be careful when cutting the door - easy if you have the right tools and are patient.
