Need Battery Suggestions
Old Jun 29, 2009 | 09:01 AM
Talyn's Avatar
Talyn
Okay, a few searches all giving me the same results of everything but a battery suggestion.
I need new batteries, What should I grab?
I don't want to throw in too crappa a batteries but want some decent ones.
Also, I need to clean the screen. Diesel clean really made a mess in my fuel system.
If i stand at the front of the truck, its the part that bolts on to the right side of the fuel bowl (Drivers side) Correct?
I take that off and clean screen? I cleaned the inside with a q-tip, and it was super dirty, So i know it has to be cleaned.
Fuel in the fuel bowl was really dirty also.
Old Jun 29, 2009 | 09:05 AM
Brown Falcon's Avatar
Brown Falcon
If someone has a pic of where the screen is that would be awesome... I looked for it yesterday when I did my FPR shim but I'm still not sure.
Old Jun 29, 2009 | 09:10 AM
Cuda_jim's Avatar
Cuda_jim
William, I would get the most CCA's you can afford....along with a national warranty since you travel so much. Most batteries are made by only a hand full of companies. The sellers just have their label stuck on them ie. Napa, Autozone, Sears ect.
If your fuel bowl is that dirty then remove it and give it a good scrubbing along with new rubber fuel lines. Remove the fuel heater to get access to the bottom of the housing, You can disassemble it on the bench. Use new o rings just for insurance.
Old Jun 29, 2009 | 09:16 AM
Cuda_jim's Avatar
Cuda_jim
Here's a couple pictures.
The screen is sandwiched in between the FPR housing and fuel housing.
Most crud will accumulate inside the filter housing.
The first picture shows the outside of the FPR housing, the screen goes on the other side...I need to get a better picture.
Old Jun 29, 2009 | 09:23 AM
Talyn's Avatar
Talyn
Nice pics.
I don't have time to do all that right now Jim. Just gotta clean the screen.
I'm not sure how easy or involved it is.
But, I'm leaving tomorrow morning, and I don't want to spend the rest of the day in 100F weather disassembling my fuel bowl.
Old Jun 29, 2009 | 09:46 AM
Talyn's Avatar
Talyn
I'ma run and get some napa batteries, they are highest crank and cheepest.
Pluss them a-holes sent me the wrong oil the other day, so I'ma take that back.
I got some bad connections on the cables I have to fix when I get home as well. I'm sure they didn't help.
Then hopefully I can get it started and back to the barn to work on the fuel problem.
Old Jun 29, 2009 | 10:28 AM
superduty4x4's Avatar
superduty4x4
Walmart or Costco for batts, lowest price I could find ($75 per), same warranty (3/5 IIRC), 850cca/1000 ca.
Old Jun 29, 2009 | 11:33 AM
Talyn's Avatar
Talyn
I got napa golds for 84 a piece.
One of my connectors was really bad. I pulled the wire out. =\
Gotta fix it. Was probably only cranking on one battery.
Old Jun 29, 2009 | 12:08 PM
Talyn's Avatar
Talyn
Damn wire is sooo bad, I cannot even solder it.
Old Jun 29, 2009 | 12:22 PM
Talyn's Avatar
Talyn
Uhm, ******* alert.
I uh, forgot which cables go to which posts?
Passenger side goes normal, and drivers side goes backwards?
Old Jun 29, 2009 | 12:26 PM
maverick1701's Avatar
maverick1701
Jim maybe you could shed some light on this for me. I have always heard "buy the most CCAs you could afford" and it makes sense but even if the battery is made for a different vehicle but has higher CCAs than the batteries made for our trucks we should buy those?
Old Jun 29, 2009 | 12:39 PM
Talyn's Avatar
Talyn
N/m i got it.
Old Jun 29, 2009 | 12:40 PM
Talyn's Avatar
Talyn
I think batteries are batteries as long as they are not deep cycle.
Old Jun 29, 2009 | 12:45 PM
superduty4x4
If they fit under the hood, run 'em. And as Talyn said, no deep cycle.
Old Jun 29, 2009 | 01:24 PM
Talyn's Avatar
Talyn
I ran a deep cycle in my 150, but it was rough on the alternator.
Deep cycles need to be cycled mostly dead and live again, otherwise they loose their power.
It treated me good for a long time though.
