Now a Clutch Problem...
Old Jun 29, 2009 | 07:45 AM
salem88's Avatar
salem88
Put in the new starter started it up was putting the clutch in and stalls. The rpms are fine in neutral but once I put the clutch to the floor it dies??? It will not start with the clutch in only in neutral,,, Any suggestions? I tried looking for wires or pinched fuel lines but nothing. Looks like my throw out bearing is not going in too far, but would that make it stall?
Old Jun 30, 2009 | 12:07 AM
garbz2's Avatar
garbz2
It would make it stall if the clutch is not dis engaging correctly and is still clamped. Just like jamming it in gear at idle.
Check the freeplay on the pedal and the linkages for roper throw out travel.
Garbz
