Trans question
Old Jun 28, 2009 | 10:10 PM
kulteras's Avatar
kulteras
Trans question
How can I tell if a C6 transmission will bolt up to my 1999 5.4L Triton? I've searched advance adapters but I can't find this info.
Old Jun 29, 2009 | 01:11 AM
85e150's Avatar
85e150
A C6 won't bolt up to a Triton. IIRC some early mod motors had the sbf bell pattern, but that ended in the first year, again IIRC.
You can get a bell for a C4:
http://www.tciauto.com/Products/Ford/ford_c4_c6.asp
But since the C6 bell is integral, it would require an adaptor. And I would guess this is not a popular swap, as no adaptor is to be found:
I also looked on AA, and a couple of trans sites.
You might call AA, maybe they can cut you one.
Old Jun 29, 2009 | 08:01 AM
kulteras's Avatar
kulteras
Thanks for the info. I had gotten ahold of AA but they said they couldn't machine one. The only reason I am thinking about this swap is because the current trans is fried and I have a 400 that I want to put into the truck, just don't have the time now. So instead of repairing the current trans, which I wouldn't use once I did the swap, I was just seeing if I could use the C6 which I am going to be using with the 400.
Old Jun 29, 2009 | 03:59 PM
85e150's Avatar
85e150
There are C6s that will fit 400s. Same bell as 351m, 429/460.
Your OP says you are trying to match to a 5.4.
Hope you can find your answer(s).
Old Jun 29, 2009 | 04:49 PM
kulteras's Avatar
kulteras
Well I have the 5.4 in the truck right now. I have to replace the current trans, and I have a C6 with a 400. Until I get the time/money/equipment to put my 400 in, I was looking to see if there was some way I could use the C6 with the 5.4 or if I was totally screwed in that deptartment. Sorry for the missunderstanding.
