Sponsored by: Real Truck
??? brake sensor ??
Old Jun 28, 2009 | 11:34 AM
55krazy's Avatar
55krazy
??? brake sensor ??
I have a 2004 F-350 and attached the the brake pedal is an electrical box with a wire running up under the dash. Two days ago something under there has been buzzing/vibrating. When the brake is slightly touched the sound stops..........or if i slightly move the electrical thing attached to the pedal. Any thoughts???
Old Jun 28, 2009 | 12:56 PM
ReAX's Avatar
ReAX
There should be a small plunger type switch right on the pedal's arm. It activates the brake lights and deactivates the cruise control. Unless it's making a short, I can't imagine it making a noise, maybe something is loose and causing a mechanical vibration. I would start by spraying some white lithium grease around the pivot points.
Old Jun 28, 2009 | 08:20 PM
olfordsnstone's Avatar
olfordsnstone
https://www.ford-trucks.com/forums/5...any-ideas.html
stevie624
Dec 8, 2012 05:37 PM
Galendor
Oct 9, 2011 09:32 PM
stevie624
Jul 31, 2011 05:49 PM
TOW4H2O
Aug 14, 2007 02:35 PM
banjoenvy
Electrical Systems/Wiring
Oct 6, 2004 09:15 PM
