Sponsored by: Real Truck
speedo not working
Old Jun 27, 2009 | 11:14 PM
bullet00's Avatar
bullet00
speedo not working
have 99 250sd with 5.4 abs light came on speedo stoped work and trans shifts hard 1to2 2to3 chandes vss on rear end abs light when out speedo trans did not change eng light is on any info or suggestens would be great thanks
Old Jun 28, 2009 | 12:28 AM
ReAX's Avatar
ReAX
You don't have the HEC cluster, but it may need the code cleared to sent the info to the cluster. Get someone to clear the code, or disconnect the battery and turn the headlights on. If the ABS is workings (light off) then the VSS signal is getting to the modules.
Maybe someone has a diagnostic procedure for the pre-HEC cluster?
Old Jun 28, 2009 | 09:28 AM
bullet00's Avatar
bullet00
will give it a try thanks
Old Jun 28, 2009 | 08:13 PM
bullet00's Avatar
bullet00
disconnected the batt. with the lights on and speedo works again and trans is shifting right thanks very much brad
