Shifting issue?
Old Jun 27, 2009 | 10:25 PM
mudmaker's Avatar
mudmaker
Shifting issue?
Was driving our X today and when I mashed the throttle at the stop light everything was normal until it went to shift. It acted like it had gone into neutral. Let off and it shifted. If I got on the throttle hard, but didnt go WOT it shifted perfectly.
Any ideas?
Old Jun 28, 2009 | 04:08 AM
CanadianSmokie's Avatar
CanadianSmokie
I just did a search on that yesterday and Springer Pop had a good hypothesis about infrequent, WOT hard shifts. He thinks it is due to a worn accumulator valve that sticks when the line pressure is higher causing the valve to stick then release. There is an inexpensive, upgraded valve assembly from Sonnex for around $40 iirc. Just do a search in this forum for hard shifts and you should find Springer Pops comments.
