The wipers finally quit working on my old truck that gets me to work and back. If I remember right the motor made a slight grinding noise sometimes but they worked. I rarely drive in rain so I never paid much attention to it.
So my question is how do I know if its the motor, relay, or switch? The wipers are currently stuck upright and are trying to return to the down position.
i pulled the cowl and did it in about 20mins, you have to bend one of the tabs on the end of the cowl up then bend it back in place when you put it back on
remove bottom windshield trim, screws in the holes on top, where wipers comr through, I think there's 4. then the ones under hood behind the gasket. radio antenna has to be seperated. easire to fight it through the hole.
