Accelerator pedal sticks when closed
Old Jun 26, 2009 | 03:52 PM
thedoctor's Avatar
thedoctor
My gas pedal sticks when completely closed, then is fine while in use. What do I have to lube to make is smooth from the start?
Old Jun 26, 2009 | 03:55 PM
alxsnmr's Avatar
alxsnmr
Try lubricating the cable starting at the throttle body. Also look at the cable at the throttle body to see if part of it has become bad enough for the plastic pieces to fall apart inside the spring. If so then you may just want to find another accelerator cable from another truck as yours may be misaligning and sticking at the fully closed postion.
Amish Ford
Jul 13, 2016 06:04 PM
SagebrushRR
Jul 25, 2010 07:58 PM
redbug
Nov 25, 2003 07:29 PM
73highboy4x4
Nov 9, 2003 12:18 AM
