Sponsored by: Auxito
Automatic Door Locks 2003 F-150
Old Jun 26, 2009 | 12:35 PM
chippah4's Avatar
chippah4
So, I have a 2003 F-150 with a Ford keyless security system. Not sure if it's related but, I just recently added a new remote (from the dealer) and the automatic door locks stopped working. I like the auto door locks, feels safer with the kids. The auto door lock feature recently stopped working and I tried to reactivate it according to the directions in the manual. The procedure did not work at all. Does anyone have any ideas??? Not sure what other info is needed, so please ask.
Thanks,
Chip
Old Jun 26, 2009 | 01:02 PM
KingRanchMan02's Avatar
KingRanchMan02
Welcome to FTE chippah4! Did you try the procedure more than once? Good luck!
Old Jun 26, 2009 | 01:48 PM
chippah4's Avatar
chippah4
Bummed
Yeah, tried 5 times. I opened and closed the doors between tries to make sure they were closed. Nothing.
Old Jun 26, 2009 | 02:26 PM
KingRanchMan02
Is this the procedure that you tried?
Deactivating/activating the autolock feature
Before following the procedure, make sure that the ignition is OFF and
all vehicle doors are closed.
You must complete steps 1-7 within 30 seconds or the procedure will
have to be repeated. If the procedure needs to be repeated, you must
wait 30 seconds.
1. Turn the ignition key to ON.
2. Press the power door unlock control three times.
3. Turn the ignition key from ON to OFF.
4. Press the power door unlock control three times.
5. Turn the ignition back to ON. The horn will chirp.
6. Press the unlock control, then press the lock control. The horn will
chirp once if autolock was deactivated or twice (one short and one long
chirp) if autolock was activated.
7. Turn the ignition to OFF. The horn will chirp once to confirm the
procedure is complete.
Old Jun 26, 2009 | 03:35 PM
chippah4's Avatar
chippah4
Keep trying
Yeah, no chirps, no changes... not sure what the deal is. Tried numerous times with no response.
Old Jun 29, 2009 | 05:32 PM
bc11's Avatar
bc11
I would check the push button switch in the door jamb. They stick and give faulty door ajar alarms. Sticky switch may cause the autolock not to engage. Someone can correct me but I think they spray them with wd40 or some silicone lube to free them up. Maybe use some carb cleaner or brakeleen first.
My 2000 f150 has a delayed autolock on the passenger side. I had replaced that door lock once. I may have to remove the door panel to see if any spray lube will help it. I may be shooting in the dark here but it is a start. Could be dirty switch contacts somewhere or a intermittant relay starting to go bad.
Do the locks work allright with the remote and the switches on the doors? Any sluggish movement like you need to lube where the button slides?
