Have codes...Need advise
Old Jun 26, 2009 | 08:25 AM
TXsnyper's Avatar
TXsnyper
P0262 injector circuit high cylinder 1
P0263 cylinder1 contribution or balance malfunction
P0341 cam shaft position sensor
sensor circuit range/performance
P2617 crankshaft position output circuit/open
This is how the codes where displayed on a Matco "computer ,code reader, tester thing"
My plan is to change the cam position sensor first, simply because it's a relatively cheap part and somewhat easy to change, but nothing is "easy" right now in this Houston heat.
The truck is an 05 with 104K on her.
Anyone know the part number for the cam position sensor?
Any other suggestions about what I should do?
Anything helps...Thanks
