Tachometer
Old Jun 26, 2009 | 06:06 AM
CDF302v8's Avatar
CDF302v8
Tachometer
Hey Y'all,
Yesterday i went to a local junkyard and pulled myself a gauge cluster with a factory tachometer for $35.
I really want a factory tach for my 1985 F-150 but can you just install the tach and not the whole cluster? If so, then how?
Thanks!
Old Jun 26, 2009 | 06:31 AM
TexasGuy001's Avatar
TexasGuy001
You should be able to. You will just have to carefully disassemble the cluster. I would recommend laying down a towel on the workbench to keep from damaging it.
Old Jun 26, 2009 | 06:56 AM
ctubutis's Avatar
ctubutis
You'll need to swap out the circuit films (shown in another recent post) but this is only
doable if your existing cluster already has gauges and not idiot lights. About the only
tools you'll need is a Phillips screwdriver, a 1/4" socket, a slightly larger socket (I forget the
size, it's for removing the "nuts" that hold the gauges to the plastic cluster) unless you need
pliers or sumthin' to get the speedo cable off. Well, unless you have an auto tranny, in
which case you've got that little gear indicator thinger, I have no idea how to deal with those
other than to cut the cables with wire cutters.
Old Jun 26, 2009 | 07:11 AM
uncle.stosh's Avatar
uncle.stosh
My god, yet ANOTHER tach post.......
There are at least 2 separate threads about tachometers on the first page!
Old Aug 27, 2009 | 09:04 PM
CDF302v8's Avatar
CDF302v8
Where does the tach wire into?
Can i swap the idiot lights for the gauges?
Old Aug 27, 2009 | 10:06 PM
ctubutis's Avatar
ctubutis
The tach wires ultimately connect the tachometer and the coil. If you don't have a tach right
now, you might have half of a pigtail connector near your electronic ignition box on the
driver's side wheel cover; the existing half of the connection (two wires; black/green dots,
green/yellow dots) goes to the coil, you will need the other half - the wires leading from
there to the tachometer on the dash.
I really don't recommend trying to swap idiot lights for gauges; I did it once and it took a
long time and I never even tackled getting the ammeter to work, I merely decided to get
another wiring harness from a JY.
miashley150
13
Aug 22, 2013 11:34 AM
wiesman2613
Aug 30, 2012 05:55 PM
dwanderson
26
Apr 15, 2010 03:54 PM
Zebich
Feb 20, 2005 10:20 PM
buzzer
Dec 21, 2004 01:19 PM
