Need Help with Camper
Old Jun 25, 2009 | 11:14 PM
titanminator's Avatar
titanminator
I have 2000 CC dually and looking for camper tie downs. i found this one on craigslist and was wondering if it will work. The guy says it maybe for a ford. Let me know what you guys think so I can pick this up this weekend.
http://seattle.craigslist.org/kit/rvs/1240180902.html
Old Jun 26, 2009 | 12:18 AM
StillNotKing's Avatar
StillNotKing
These look to be the "stake and pocket" type rather than the "slide-in" type. If so, I would say that they are probably the kind you are looking for.
I have a light Starcraft pop-up, and I made the mistake of getting the "slide-in" type originally. After bending the truck bed at the cabin and bending one of the tie-downs into a pretzel, I changed to the stake-and-pocket type and have had good results since.
One suggestion, though: Get a spring tensioner set and install it with your chain/hook/tightener assembly. You'll save yourself a huge headache down the road.
Old Jun 26, 2009 | 08:19 AM
milleroutdoors's Avatar
milleroutdoors
If you can afford them spring for the torklift frame mounted tie downs. They are receivers mounted to the frame and the tie down extensions come off so when not hauling they are out of site
Old Jun 26, 2009 | 08:27 AM
DISLFVR's Avatar
DISLFVR
Locomotive breath
I have Happi-jac frame mounted tie-downs and have used them for several years with no problems. Stake pocket tie-downs are ok for something lite-weight, say no more than 1000 lbs. My t-c weighs about 3000 lbs. loaded.
Old Jun 26, 2009 | 05:29 PM
titanminator
So do these look anything like what you guys are recommending?
Old Jun 26, 2009 | 07:08 PM
milleroutdoors
No they do not. I will try to find a link for you or you can check e-bay to see what the torklift and the happi-jack look like.
Old Jun 26, 2009 | 08:30 PM
Calli's Avatar
Calli
just put torklift in your search
Old Jun 26, 2009 | 11:13 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
http://www.happijac.com/
Here's happijac's link.
Old Jun 26, 2009 | 11:20 PM
titanminator
thanks guys. ill be doing more searching
Old Jun 27, 2009 | 12:32 AM
preppypyro's Avatar
preppypyro
For my 03 supercab shortbox, I bought dsp stuff. Easy to install, and cheap. I like the torklift stuff, but for the prices they want, forget it.
