I've noticed that the LL system on my 98 seems to adjust itself frequently even while driving I can hear the compressor come on - since I don't know what is normal - can anyone tell me why or what may be causing this to happen????? thanks in advance.
It tries to keep a constant ride height so it will always adjust . The system will lower the truck after the last door is shut and for a per determined amount of time after the ignition is cut off.
My 98 Navigator cycles too...make me think it has a leak somewhere but it does not due it often. I think I read somewhere that it may lower the suspension above 30 and raise it below 30mph. I have a 2WD.
