Crankcase Evacuation
Old Jun 25, 2009 | 11:38 AM
mwvdub's Avatar
mwvdub
I had new headers built for my 79 F100 over the winter with evac tubes in the collector. I looked inside the header and the tube is installed about halfway in the collector, about 2" installed depth, and not cut at a very good angle to the flow. I pulled the valve cover breather and it seems the tube is actually blowing back into the valve cover instead of sucking pressure and running it out the exhaust. I replaced the check valves but still not helping much. Should I shorten the tubes and cut them at a 45 degree angle to the exhaust flow?
LARIAT 85
May 12, 2009 04:28 PM
rat49f6
Apr 4, 2009 09:22 AM
fordxlt150
19
Mar 16, 2009 10:55 PM
macwilj
Jul 28, 2007 08:26 PM
