2003 Excursion hum when accelerating slowly
Old Jun 25, 2009 | 10:24 AM
PA Chuck's Avatar
PA Chuck
After buying my 2003 Excursion I took a buddy for a ride, and he just happens to be a qualified service tech, and while accelerating slowing at around 35 mph he said "what's that sound?" I hadn't heard it before he mentioned it, but when accelerating slowly I hear this hum or vibration at 35 mph and it goes away around 40mph, and if I continue to accelerate slowly I hear it again at 50 mph and it goes away around 55. If I accelerate quickly from a stop I don't hear it at all. I've checked my front wheel hubs and there are in auto mode. This sounds like it is coming from the front of the vehicle.
Should I be concerned?
Old Jun 25, 2009 | 11:12 AM
DaveandJennyP's Avatar
DaveandJennyP
Mine has an exhaust heat shield that buzzes off an on. I have put a couple hose clamps on but haven't found the exact spot of the buzz yet. It's like you said only at certain times.
Old Jun 25, 2009 | 11:30 AM
PA Chuck's Avatar
PA Chuck
Hadn't thought of that. I suppose that could be it. Much rather that than something in the drive train. Thanks!
Old Jun 26, 2009 | 12:05 AM
EXv10's Avatar
EXv10
Probably something touching someting else just enough to produce a resonating effect at certain harmonic frequencies.
Old Jun 26, 2009 | 06:22 AM
myblkex's Avatar
myblkex
Mine does EXACTLY what you are describing. It only does it on light acceleration at around 35 and then again at 50-55. Feels like it's a droning/vibration down the front mid section of the truck.
I noticed that it is not speed relative though - but rather rpm. Take it out of OD and drive it the same manner and you'll see it no longer does that sound at those particular speeds - but instead at those exact rpms. It happens when you give it light throttle while cruising when the rpm's are at just about 1500-1600. It does not make the sound if you let off the gas during the drone or if you give it more gas and push through the rpm range...
I still have no idea what it is exactly though
Old Jun 26, 2009 | 06:29 AM
jdadamsjr's Avatar
jdadamsjr
Is it possible it is the radiator fan coming on due to heat ?
mine RARELY comes on and when it does, it could could a distant hum with the windows up and ac and radio blasting away....
Old Jun 26, 2009 | 06:52 AM
Monsta's Avatar
Monsta
Sit. Stay.
+1. The heat shield welds can break and still look good but will buzz at particular RPMs. It is a very common malady.
Other similar issue is the inspection plate on the front of the transmission.
Old Jun 26, 2009 | 08:05 AM
PA Chuck's Avatar
PA Chuck
Thanks all. Sounds like I am not alone and that this is not a rush it to the transmission shop kind of problem. I'll try the RPM test. Makes sense to me. I LOVE this Excursion! Tell your friends that this is a great time to by a gas guzzler! Ford gas guzzler, that is!
Old Jul 1, 2009 | 02:47 PM
PA Chuck's Avatar
PA Chuck
Definately RPM related, and mlbekex was right, doesn't happen with the overdrive off. I'm learning to live with it. Sure do love this Excursion!
