Tranny Swap
Old Dec 4, 2001 | 07:54 PM
budcross's Avatar
budcross
Tranny Swap
[updated:LAST EDITED ON 04-Dec-01 AT 08:59 PM (EST)]Apparently I'm in the minority here but what would be involved in switching to an auto transmission from my stock 5-speed? I have a '91 F150 2WD with the 300/6 and the 5speed manual trans. Which auto trans would be best? Thanks for any comments.
Old Dec 5, 2001 | 11:31 AM
deere81's Avatar
deere81
Tranny Swap
Well if I were you I would swap in an AOD transmission. If you plan on doing a lot of pulling I would go with an E40D.
'90 F-150 351 AOD "The General"
'78 F-250 460 C-6 "Old Green"
'93 Mustang LX 5.0 AOD
Old Dec 5, 2001 | 12:21 PM
Gates's Avatar
Gates
Tranny Swap
Well I just did the same swap this summer so here goes. Mine was alittle more complex due to my truck being a 4x4. I swaped in a new 302 and went from a 5 speed (mazda) to a C6 I keep the BW1356 xfer case.
With a 2wd it is really straight forward. You will need the transmission, flexplate, torque converter, tranny cooler or new radiator with one in it, new steel lines for the tranny, steering column, and depending on what u use maybe a new drive shaft. (I had to get 2 new ones made up, shortened one and lengthened the other) Besides that there are little misc. stuff you will need.
Depending on what tranny u use, AOD,E40d, C6, C4 will determine alot also. With the E4od you will need a new computer to handle the tranny. I would stay away from that, go with a C6 (bulletproof), or an AOD for the OD. Make sure you get the right flex plate other wise you motor will be out of balance and that is bad.
If you have any questions let me know. God knows I have spent enought time under my trucks or friends trucks.
Old Dec 5, 2001 | 12:23 PM
Gates's Avatar
Gates
Tranny Swap
[updated:LAST EDITED ON 05-Dec-01 AT 01:24 PM (EST)]Oh yeah if your near Wisconsin I have a C6 from my old truck forsale. I rebuilt it with a B and M kit, 30k ago. Its from a 1986 F150 2wd for a 300,302,351 engine.
Old Dec 5, 2001 | 08:54 PM
lairdramsay's Avatar
lairdramsay
Tranny Swap
