hard steering
Old Jun 24, 2009 | 05:35 PM
pod man's Avatar
pod man
Unhappy hard steering
Ok, I did a quick turn in the dirt and now my steering is hard at an idle. If I raise the rpm's it gets easy. Fluid level is good. I noticed less braking power also (like a bad vacuum booster) again raise the rpm's and the brakes get better. Can these two systems be related? It's an 07 350 CC KR 6.0
Thanks in advance.
Mark
Old Jun 24, 2009 | 06:55 PM
KRDiesel's Avatar
KRDiesel
Yes, the power steering pump also is used for the power brakes. Check your fluid level.
Old Jun 25, 2009 | 07:40 AM
lawnboy1965's Avatar
lawnboy1965
Mine was doing the same thing this week and they put in a new pump and all is good. Ford has never been known for having great power steering pumps. There is a version 3 out now and it seems to be doing good.
Old Jun 25, 2009 | 08:08 AM
fixxxer-upper's Avatar
fixxxer-upper
FTE Fan
I agree with lawnboy1965. My truck was doing the same thing at only 77K miles. Steering pump went out and I had to replace it. No problems since.
https://www.ford-trucks.com/forums/8...ing-flush.html
post #11 is how I flushed my system out, very easy.
Good Luck.
