Abs
Old Jun 24, 2009 | 12:28 PM
flashart24's Avatar
flashart24
Abs
My ABS light blinked on a couple times last week after hitting the same bump at work.It came back on Saturday and stays on now. Plugged programmer in and cleared a couple of codes but the light will not go off.Should I be checking for something else? 07' 6.0
Old Jun 24, 2009 | 12:36 PM
SOB Racing's Avatar
SOB Racing
Had the same problem! It was the speed sensor on the rear diff. Your sensor could be bad or you could have a bad connection at the sensor plug. I bought a new sensor and the problem went away.
Old Jun 25, 2009 | 07:56 AM
l-m tech's Avatar
l-m tech
What where the codes.
Old Jun 25, 2009 | 01:26 PM
osumaxx's Avatar
osumaxx
Similar problem here, except after a period of time with the ABS light on, my speedometer would zero out while driving then start working again and I'd have some brake pedal feedback. Rear speed sensor fixed everything.
Old Jun 26, 2009 | 12:08 PM
flashart24's Avatar
flashart24
where is the sensor located?
