Swapping starters. Which ones will fit?
Old Jun 24, 2009 | 08:18 AM
s.squared-39's Avatar
s.squared-39
The starter went on my spare/parts truck. I was just going to go to the wreckers and find one there. My truck is a 78 F-250 4x4 standard with a 351. How specific is the starter? Will one from a 2wd fit? From a auto? Just 77 to 79 or can I look for one off a newer truck?
Old Jun 24, 2009 | 09:42 PM
Embreechristopher's Avatar
Embreechristopher
351 what?
because Ford has 3 different 351s
351 Windsor (small block) biggest of the small blocks
351 M "Modified" (Big block) basically a down stroked 400
351 Cleveland (Big block)
Old Jun 25, 2009 | 01:18 AM
65f100_352's Avatar
65f100_352
Sorry bud, the 351C isnt technically a big block, they have the same bore spacing as a Windsor, and even the same bolt pattern. The 289/302/351W/C have the same bolt pattern, whereas the 351m/400/429/460 has the same bolt pattern. The 351 modified/400 has a taller deck height than the 351C, which is what their based off of, so I'd think that thats were the modified came from, but I'm not sure.
Back to the OP's question, I think that ford had 2 main different starters, and I could be wrong, the two bolt and the three bolt.
Old Jun 25, 2009 | 08:19 AM
s.squared-39
I believe it is the 351 M. What is the best way to tell?
Old Jun 25, 2009 | 08:31 AM
hoxiii's Avatar
hoxiii
You can use an automatic starter on a manual, but you shouldn't use a manual starter on an automatic.
Reasoning being they have different engagement depths and using a manual starter will eat the ring gear more quickly.
Also as for the two vs. three bolt starters, not all two bolts are the same. Some of the throwout assemblies are clocked differently.
Just take your old starter with you and get one that matches.
Old Jun 25, 2009 | 01:22 PM
65f100_352's Avatar
65f100_352
351C/m/400 = 8 valve cover bolts
