Tranny problems
When this happens, I've noticed that the tachometer will also quit working simultaniously. Does the the tach have anything to do with the tranny shifting? Through the ECM?
It does this very speratically. This is driving me nuts
, plus can't be good on the tranny.Thanks!
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden"><input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden"><input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
the E4OD needs input from several sensors including, the Range Sensor (connected to the shift lever), the Throttle Position Sensor, the Tach and the Vehicle Speed Sensor.
I would assume your O/D light is blinking, if so, you need to get the codes read at a transmission shop to try to identify the faulty sensor.
