Take care of your coolant:
The Premium Gold colant does have the protection in it, but after having my radiator replaced and the dealership leaving my tranny 3.5 qts low, then filling up my degas bottle from a water hose I felt I needed to check the strength of the additive. Just dont trust them anymore.
Yeah, under those circumstances I understand your cause for concern.
What is even more sad is that I feel FORD has really begun to build some really nice vehicles in the past few years. If the quality of the service department's work was anywhere near as good as the quality of the vehicles FORD is releasing, it would be a great day to own a FORD. Unfortunately this is not the case.
This could be true with other manufacturers as well, but I've only had the opportunity to deal with FORD lately.
The quality of the tech's has alot to do with the region you live in for the most part. There are so many Ford dealers in the US and not that many top level techs. Naturally the better techs will go to the bigger dealers that pay more. Also, I tend to look for dealers that sell alot of the Super Duty work trucks, because it will command a larger need for diesel techs. We have 6 Ford dealers in less than 20 miles here in South Jersey, and only one has good service. So using that ratio 1 out of six dealers has good tech service. That being said, I always ask to meet the guy that is set to work on my truck, because it establishes a personal connection and he will think twice about short changing me. This has allowed me to have very few issues at service, but come to think of it maybe its because I am a 6'2' 225lb potential problem for him Also, where the heck can I get gold coolant? I went to NAPA as suggested and the only thing close was Zerex G-5 or sumthing?? Any help??
The Zerex G05 is the same as ford gold so that is what you want. Just be sure you know if you are getting full strength or the 50-50 mix. Either is find just make sure you get the water ratio correct.
"3Take Care of Your Coolant
The coolant concentration should be maintained at 50/50 mix of coolant and distilled water. The level of coolant should be maintained at the "COLD FILL" range in the coolant reservoir. If you suspect any coolant system leaks or lack of cooling, pressure test the cooling system. Refer to your Owner Guide for additional information.
Engine coolant system nitrite strength should be checked and serviced at the mileage or equivalent hour intervals specified by the maintenance schedule. Check coolant nitrite strength using the 3-Way Antifreeze Test Strip kit Rotunda # 328-00001 to determine if additive is required. If the nitrite strength is between 800 ppm & 300 ppm add 32 fl. oz. (946 mL) of Supplemental Coolant Additive Motorcraft VC-8 or equivalent. If nitrite strength is below 300 ppm flush & refill engine coolant (refer to Motorcraft Premium Gold Engine Coolant Change Record) – Do not add Supplemental Coolant Additive if flush & refill is required."
#28
The instructions said 800ppm to 300ppm add 32oz. So that's what I did.
#30
