Carb Help
Old Jun 23, 2009 | 02:29 PM
dirtballer's Avatar
dirtballer
Carb Help
I finaly got around to rebuilding my 4150 carb and got it all back to geather and i notice the accellarater pump was leaking gas took it back off and one of the screws was striped out so what can i do to fix this ?
Old Jun 23, 2009 | 10:32 PM
Franklin2's Avatar
Franklin2
Look in the hole and see if there are any threads left in the bottom. If so, you can find a longer screw and try that. You could also fill the hole with jb weld and then drill and re-tap the threads.
