Stuck in Park
Old Jun 23, 2009 | 12:49 PM
Scottk250sd's Avatar
Scottk250sd
Stuck in Park
Hello All,
My PSD tends to get stuck in "P" at times. It's intermitent right now but I'm worried it may happen for good when I'm away from home.. Is there a switch or sensor that could be going bad? When it happens, I have to mash the brake pedal to the floor and then eventually it will click and release.
Thanks
Old Jun 23, 2009 | 03:11 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
It's prob the brake on/off switch at the top of the brake pedal. Some call it the BOO switch.
Old Jun 25, 2009 | 03:14 AM
GregsSD's Avatar
GregsSD
Sounds like your brake pedal switch is going bad,
In an emergency when it sticks you can turn your key 1 click forward, then shift to neutral, then start the truck.
