302 engine swap questions
Old Jun 22, 2009 | 11:57 PM
j400ex18's Avatar
j400ex18
i have a 93 f150 i did an 5.0 to 5.0 engine swap my question is i used a 98 explorer 5.0 short block with its cam gt40 cast iron heads and my 93 intake set up is my firing order is it from my 93 5.0 or the 98 5.0 and what distibitor do i need to use and does any one know about how many horse power i should have
Old Jun 23, 2009 | 07:14 AM
Conanski's Avatar
Conanski
The plug wiring order has to be the same as the cam so that means it should be 13726548 for the Explorer motor. If both distributors are the same then you can use either one but if not use your '93 dizzy. Engine output would be something other than the factory rating with the truck intake on it and whatever exhaust you have, but the motor itself is capable of around 260hp as is and over 300hp with a different cam.
Old Jun 25, 2009 | 01:21 PM
j400ex18's Avatar
j400ex18
the explorer didnt use a dizzy and mine wont go over the hex shaft that drives the oil pump any ideas on what i can get a dizzy out of that will work
Old Jun 25, 2009 | 04:51 PM
1966Tbird's Avatar
1966Tbird
pull the pan and oil pump and put in a melling with a hd shaft that a dissy will fit
