Tremec TKO 5 speed help!
Old Jun 22, 2009 | 10:56 PM
70torino429's Avatar
70torino429
Ok, so im going to be buying a tko 5 speed for my 90 crown vic with the 351. The question is what kind of bellhousing do i need to use?
I think i can figure out what clutch and flywheel to use since it tells me its a 26 spline input shaft, so obviously a 26 spline clutch disc, but if someone can tell me what diameter clutch i should be using it would be a big help.
Old Jun 22, 2009 | 11:19 PM
70torino429
Ok, i actually found the bellhousing i need from lakewood. its lakewood part number 15202, but i cant find out what size clutch is supposed to be used for it, i know it needs to be 26 spline, but what diameter?
Old Jun 23, 2009 | 12:23 AM
85e150's Avatar
85e150
Your flywheel is drilled for the pressure plate. Some will take either a 10 1/2 or an 11. Go for the 11.
That Lakewood bell specify that it is the correct depth for your trans?
Old Jun 23, 2009 | 01:18 AM
70torino429
Im buying a new flywheel, pressure plate and clutch assembly.
What ive been told thus far is that the 10.5" will work good. Would it really benefit me to go to an 11" clutch?
Old Jun 23, 2009 | 01:50 AM
85e150's Avatar
85e150
I had a 10.5 in a Mustang behind a 289. I'd want all I could get in your application.
