what kinda boost levels do these trucks run stock? and whats the most boost that can be turned out of these turbos and any upgrades to help them work better?
yeah like falcon said, with your foot in it at stock youll get 15 and 18 at most, but a downpipe really helps and then tunes will set you over 20, but you dont want to go much over 25 any how, journel bearings are not stable enough in these stock turbos to handle that much
I just put a boost gauge in this past weekend and I am surprised at little boost there is during normal driving. Basically need to be going up a hill or accelerating hard. Even driving on the interstate at 65 and 1700rpm, there might be 1-2 psi. I thought I would be seeing 5 psi for normal driving, but I thought wrong.
I haven't put my foot into it too much since the gauges but have seen it a little above 15, maybe close to 17. Maybe I will try it this afternoon sometime, if I do I will let you know.
I got on it a couple of times and saw 17pounds for a second, just before upshift. Might be 1 or 2 psi more if pulling hard up hill but I think that might be it.
Maybe the reason some guys see more is at what altitude they are at. Not sure if this is correct but someone in Colorado might see higher boost because of thinner air then someone in Florida. In Vermont I am generally in the 500-1500 ft range.
