Sponsored by: Auxito
Hard Shifting into 4WD
Old Jun 22, 2009 | 10:05 PM
tim6409's Avatar
tim6409
I'm having an issue shifting my 99' XLT from 2wd to 4hi/lo. I had the tranny rebuilt a couple years ago, at that time I was unable to shift into 4wd at all. The guy who rebuilt said there was nothing mechanically wrong everything had just seized up. He lubed it and I was able to shift relatively easy.
My normal mechanic said this is common because water leaks in and causes the mechanisms to lock up. He dropped a couple drops of oil in and it helped the last time it started to stick. Is this a common problem and are there any good solutions to fix this for the long haul?
Old Jun 23, 2009 | 08:55 AM
KingRanchMan02's Avatar
KingRanchMan02
Welcome to FTE tim6409! I do not have first hand experience with your trouble but, I have seen many threads with the same symptoms. The best remedy is after lubing the mechanism again and getting it working properly is to put the truck in and out of 4wd once a month to keep the mechanism working smoothly. Good luck!
hunt1moore
Modular V10 (6.8l)
Jun 1, 2015 12:34 PM
smhc
1997 - 2003 F150
Feb 9, 2015 10:21 PM
Greasemonkee
Jun 16, 2014 10:55 AM
Pigman54
Jun 7, 2014 10:25 PM
Bodaddy1969
1997 - 2003 F150
Apr 15, 2014 10:53 AM
