Funky Oder from vents
Old Jun 22, 2009 | 06:39 PM
06F150Guy's Avatar
06F150Guy
I get a funky odor from my ventilation system when switching from vent to ac and vise versa or if I start my truck with the ac on! Any thoughts on how to take care of this? With out just an air freshner which I tried already just smells funky plus the smell of the freshner!
Old Jun 22, 2009 | 06:52 PM
bridge's Avatar
bridge
Sick 'n Tired
Outside dismantling the dash and going after all the vent tubing and the evaporator core, air freshener is probably your only option.
You can tell it's getting oppressively hot out, this the second or third smelly vent thread in the last week!
Old Jun 22, 2009 | 07:11 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
at the local parts store about 2 yrs ago I bought a Deodorizing spray specifically made for A/C vents
you spray it in there and let it sit for a few minutes
then turn on the a/c and run it full blast with the windows down for 10 minutes or so...worked pretty good on my 1994 F-150 in the Seattle area
Old Jun 22, 2009 | 07:28 PM
jclem65's Avatar
jclem65
i have used a product that is a foam cleaner. there is a nozzle and tube that attaches to
your ac drip line.... push the tapered nozzle that and spray the foam for about 15-20 seconds long enough to get the foam to the evap core pull the nozzle from the drain hose
let it drip out and repeat... i usually do it three or four times. this has a anti bacterial cleaner as well a a light scent.
if anyone is interested pm me i can get them for $15.00 plus shipping.
Old Jun 22, 2009 | 07:30 PM
jclem65's Avatar
jclem65
oh yeah, there is also a small can that you can spray in the intake vents by the cowl.
Old Jun 22, 2009 | 07:54 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
sounds like the stuff I used
it looked like bathroom cleaner when it was sprayed out...foamy, and then turned to a liquid version one it had been sitting there a few minutes
Old Jun 22, 2009 | 08:12 PM
jclem65's Avatar
jclem65
yup. thats the stuff
Old Jun 23, 2009 | 08:03 AM
442w30's Avatar
442w30
If you use the recirc often you may start smelling a moldy ordor due to the ac system not drying out. Several products are avalible to spray into the cowl intake while ac is on, they kill the bacteria. After installing the spray in the future it is best to shut off ac before you park and run fresh air thru vents to dry out system. Infiniti's are nortious for this because they start up on recirc mode and most owners never switch to fresh air. I know I have one.
Old Jun 23, 2009 | 08:28 AM
Deluxe05's Avatar
Deluxe05
Turn off the AC & recirculate for the last couple minutes that you are in your truck. It will pull most of the moisture out of the core & ducts and drastically reduce the mildewy smell when you turn the system back on.
Old Jun 23, 2009 | 01:44 PM
06F150Guy's Avatar
06F150Guy
Thanks guys I'll have to give a try! My wifes 2008 Impala does the same thing and it only 1 year old!
Old Jun 29, 2009 | 12:46 AM
justinfown1's Avatar
justinfown1
most likely you need to change your cabin air filter located behind the dash. doesn't cost much....
Old Jun 29, 2009 | 02:27 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
what cabin filter?
such a thing doesn't exist in the 04-08 F-150
Old Jun 30, 2009 | 12:44 PM
1saxman's Avatar
1saxman
This, plus think about how the truck is parked after AC use. If it's not perfectly level, you may be holding condensate in the drip pan. Try reversing the angle by backing in instead of pulling in, for example, and see if more water drains out. Then you'll know to park it like that at least during AC weather.
You can buy a huge spray can of 'OZIUM' at beauty supply stores and maybe other places. With the engine running, start the AC and turn it to MAX (recycle, recirc). Go to the passenger's side, open the door and find the fan intake grille under the dash. Spray the OZIUM directly into the fan for about 10 seconds. Turn everything off and shut up the vehicle for as long as you can. The musty odor will be gone for awhile, and if you do these other little precautions, you might get rid of it.
Old Jun 30, 2009 | 12:45 PM
1saxman's Avatar
1saxman
This sounds like a good treatment too.
