Big problem...help needed
Old Jun 23, 2009 | 09:38 AM
HKusp's Avatar
HKusp
Originally Posted by john_from_ict
The windshield has been replaced so I will check a little more to see if I can tell if any moisture is getting into the cab.
Take a hose to the windshield. Run the water on it and see if it reproduces the symptoms. If it does, then you have water leaking down the inside of the firewall. It happened to my Wife's expy, months after the windshield was replaced. It was a very dry spring and summer and it took us a long time to figure it out, because it obviously only happened when it got wet, and we don't wash her truck much.
Old Jun 24, 2009 | 03:01 AM
Visseroth's Avatar
Visseroth
What about hitting it with a pressure washer at about a 1 foot or better range?
